Does the LabVIEW Application Builder Allow for the User to Select a Custom Install Option?
Updated May 23, 2018
I'm currently distributing an application using the Application Builder to create an installer. However, I'd like for the end user to be able to select a "typical" or "custom" install option when installing my application. Is it possible for the user to select specific drivers from my installer to install?
The LabVIEW Application Builder currently doesn't have native support to create an installer that allows the user to specify a typical install package or give the user the option to install specific components of your installer. This functionality can be accomplished with 3rd party software such as Inno Setup.
Additionally, you can create multiple installers for a single LabVIEW project to distribute multiple install packages.
