TestStand includes two tools for converting Test Executive Toolkit sequences to TestStand sequences. In TestStand 2010 SP1 and previous, these tools are located in the Tools menu of the TestStand Sequence Editor. TestStand 2010 SP1 is the last version of TestStand to include the LabVIEW and LabWindows/CVI Converters in the TestStand installer.
Converting to TestStand 2010 SP1 and Previous VersionsTo convert a Test Executive Toolkit sequence to a TestStand sequence for TestStand versions 2010 SP1 and earlier, open the TestStand Sequence Editor, and navigate to
Tools»Sequence File Converters»Convert LabVIEW Test Executive Sequence... or
Tools»Sequence File Converters»Convert CVI Test Executive Sequence... depending on the type of Test Executive Toolkit sequence you are converting.
Note: In order to successfully convert LabVIEW Test Executive sequences using the LabVIEW converter, the active version of LabVIEW must be between 8.2.1 and 8.6.1. Additionally, after running the LabVIEW converter, you must open the auto-generated TestStand sequence file and run the
Update VI Calls tool to ensure that the LabVIEW steps in the TestStand sequence file are correctly configured and up to date.
Converting to Newer TestStand VersionsIn order to convert to a newer version of TestStand than 2010 SP1, use an older version of TestStand (2010 SP1 or previous) to convert to a TestStand sequence file, then upgrade the TestStand sequence file to the newer version of TestStand using
the migration utility.
