You will not get accurate frequency domain readings when using an NI 9234 C Series Sound and Vibration Input Module in a cRIO chassis in scan mode. Either switch to using FPGA mode with the LabVIEW FPGA Module , or switch to using a chassis that supports NI-DAQmx .
