Voltage Spikes on Output Of PXIe-4610
Updated May 9, 2018
  • PXIe-4610
I am using the PXIe-4610 Amplifier Module but I am seeing some voltage spikes in the output signal as shown in the image below.
Make sure that you are balancing the output of the PXI-4610 by adding resistance as shown in the image below.
To make sure that everything is configured correctly, see the PXIe-4610 Getting Started Guide
Connecting a ground-referenced load or instrument to an NI PXIe-4610 output effectively short-circuits one output terminal to ground, which activates the short-circuit protection and causes the observed voltage spikes.
