Accessing the 40 Differential Analog Inputs of USB-6225 with BNC Accessories
Updated Mar 28, 2019
  • BNC-2115
  • BNC-2090A
  • USB-6225
Can I use BNC-2090A and BNC-2115 to access the 40 differential analog inputs of USB-6225 via BNC connectors?
With BNC-2090A and BNC-2115 accessories you can access up to 32 differential analog inputs. The last 8 differential channels can't be accessed with NI's BNC accessories.
BNC-2090A is the BNC connector terminal available for connector 0 of USB-6225. Connector 0 provides access to the first 8 differential analog inputs.
BNC-2115 is the BNC connector terminal available for connector 1 of USB-6225. Connector 1 provides access to the last 32 differential analog inputs of the 6225. However, BNC-2115 just provides access to the first 24 differential analog inputs of this connector.
