The Nidmfuiu.mxx Plug-In Reports an Exception in NI MAX
Updated Aug 20, 2018
  • CompactDAQ Controller
In NI MAX, after reinstalling LabVIEW, I cannot access the Software category in my CompactDAQ real-time controller. NI MAX reports that nidmfuiu.mxx plug-in caused an exception in the CmxuiRemoteItem::GetUIOptions function.
  1. Try deleting the real-time target from MAX, then to detect it again. To do it, select the real-time target, hit the delete key, and then confirm.
  2. If step 1. does not work, try resetting the MAX configuration by following the steps in this article: How to Fix or Reset the NI MAX Database File
