Error -200381 When Using PXIe-6552 at Low Sample Rates
Updated May 15, 2018
  • PXI-6552
  • NI-HSDIO
After changing my sample rate from 50MHz to 1MHz while using my PXIe-6552, suddenly I see error -1074118616 with status code -200381 when trying to run my code.
The error message mentions a minimum sample rate, but according to the specifications the minimum is 47Hz.  What could be causing this?
This error can be thrown when you attempt to set a data delay while sampling at less than 25MHz.  The minimum sampling rate to configure and use data delay on the PXIe-6552 module is 25MHz.
