Error -1074384886 at NI-XNET Write (Frame CAN)
Updated Oct 21, 2026
  • NI-9862
  • NI-9860
  • NI-XNET
I am streaming data from my NI-XNET CAN interface using XNET Write (Frame CAN) and I receive Error -1074384886 approximately every 10 seconds:
Error -1074384886 occurred at XNET Write.vi
Possible reasons(s):
NI-XNET: (Hex 0xBFF6300A) The operation timed out.
Solution: Specify a timeout long enough to complete the operation, or change the operation in a way that it can get completed in less time (e.g., read less data).
Error -1074384886 is a timeout error within XNET. To resolve this issue:
  • Run an NI-XNET shipping example, such as CAN Frame Output Steam.vi, and verify whether the error occurs.
    • Navigate to Help>>Find Examples and search for XNET.
    • If the example runs successfully, compare its configuration and implementation with the application exhibiting the error.
  • Make sure to provide external power to the NI-XNET CAN module when required by the application. High bus loads or baud rates greater than 500 kBd may result in timeout errors if sufficient external power is not supplied.
  • Update the CompactRIO or CompactDAQ chassis firmware to the latest supported version and verify that the NI-XNET driver version is compatible with the deployed software stack.
