National Instruments estimates empty chassis power draw for the following chassis:
Empty Chassis Power Draw Values for PXI(e)
| PXI-1000B | 50 W |
| PXI-1000B (DC option) | 24 W (2 A draw off 12 V battery) |
| PXI-1002 | 26 W |
| PXI-1006 | 83 W |
| PXI-1031 | 43 W |
| PXI-1031DC | 38 W |
| PXI-1033 | 52 W |
| PXI-1036 | 47 W (fan set to auto) 51 W (fan set to high) |
| PXI-1042 | 26 W |
| PXI-1044 | 89 W |
| PXI-1045 | 89 W |
| PXI-1056 | 40 W |
| PXIe-1062Q | 52 W |
| PXIe-1065 | 107 W |
| PXIe-1066DC | 145W |
| PXIe-1071 | 66 W (fan set to high) |
| PXIe-1073 | 51 W |
| PXIe-1075 | 66 W |
| PXIe-1082 | 56 W with fans on auto 72 W with fans on high |
| PXIe-1084 | 100 W (fans set to 38 W Auto) 150 W (fans set to 58 W High) |
| PXIe-1085 | 95 W (fans set to low) 125 W (fans set to high) |
| PXIe-1086 | 170 W |
| PXIe-1088 | 125.514 W (230 V, 50 Hz) 132.414 W (110 V, 60 Hz) |
| PXIe-1092 | 84W to 118W 90W to 125W (with timing and sync) |
| PXIe-1092DC | 212 W† |
| PXIe-1095 | 250 W (fans set to 38W Auto) 300 W (fans set to 58W High) |
| PXIe-1095DC | 300 W† |
† Maximum power consumption of the chassis without the modules
Empty Chassis Power Draw Values for SCXI
| SCXI-1000 | 4.5 W |
| SCXI-1000DC | 7.5 W |
| SCXI-1001 | 5.5 W |
Note: All values are approximations. Actual values may vary.
