Station global variables are variables specific to a computer, that you can access from all steps, sequences and sequence files on that computer. Any changes you make to the value of a station global variable are reflected in all other steps and sequences.
TestStand saves the station global variables in the StationGlobals.ini file in the <TestStand Application Data>\Cfg directory automatically when you close the TestStand Engine.
