Multi Chassis Synchronisation Using DAQmx
Updated May 25, 2018
  • PXI Chassis
  • PXIe-1071
I am trying to synchronise a set of DAQmx devices across two cDAQ/PXI chassis. How can I export a trigger from one chassis to another using the DAQmx API?
You can use the DAQmx API to export a trigger to any PFI line on your system. By connecting the PFI line to your second chassis you can then configure your devices to trigger off this signal. An example of how this can be achieved is shown below:
