Using AVL_IFILE DataPlugin With DataFinder Server and AVL CONCERTO™
Updated May 14, 2018
  • DataFinder Server
Other
AVL CONCERTO™
I installed AVL_IFILE DataPlugin to manage AVL PEMS files with NI DataFinder Server, with ASAM ODS interface enabled. The client used to view my data is AVL CONCERTO™ (not DIAdem).
I am noticing differences if I open the file directly with AVL CONCERTO™ or if I view the file in AVL CONCERTO™ through the DataFinder ASAM ODS Interface.
In particular, the data and the attributes visualization and organization is different between AVL CONCERTO™ (without DataFinder) and AVL CONCERTO™ connected to DataFinder Server.
Is this expected?
The behaviour is expected. You have to keep in mind the following:
  • Using DataFinder ASAM ODS Interface, the data will never look like if directly loaded by AVL CONCERTO™
  • If you want to correctly see parameters in the ASAM-Server-View of the DataFinder, each Parameter must be configured as optimized custom property
  • It is possible to search data with DataFinder and then load the original data in AVL CONCERTO™
