This device is not supported by your LabVIEW environment
Updated Mar 11, 2022
  • CompactRIO Controller
  • CompactDAQ Controller
  • PXI Controller
  • NI-9149
  • NI-9145
  • NI-9146
  • NI-9147
  • NI-9148
  • NI-9154
  • NI-9155
  • NI-9157
  • NI-9159
  • LabVIEW FPGA Module
  • LabVIEW Real-Time Module
I am trying to add my device (cRIO, PXI, Ethernet/EtherCAT Chassis, FPGA target, sbRIO, etc) to my LabVIEW project and I'm receiving the following message:
Why am I seeing this?
The reason you are seeing this is because your controller may not be compatible with your LabVIEW version. Make sure that the software environment you are using is supported by your hardware. See document Software Support for CompactRIO, CompactDAQ, Single-Board RIO, R Series, and EtherCAT and select your device model from the dropdown in Section: Show Support Information for a Specific Device. You will see the compatibility information on the table.
