Can I Use HSI and HSO Pins On My Device For RS 422 Clock Signals?
Updated Aug 16, 2018
I have an RS 422 sensor that requires a clock signal. I do not see a clock signal on my device's datasheet. I do see that there are Handshake In/Out pins, and I want to know if those can be used as clock pins.
You will be unable to use RS 422 pins as clock signals with our serial devices. Clocking is generally achieved using baud rates with serial communication, and we do not have a way to use a serial line as a clock line.
