An Input Parameter is Invalid When I Launch my RT Application
Updated Aug 20, 2018
  • cRIO-9035
I created a RT application and there was no error when I programmed it. When I tried to lauch on my cRIO 9035 with Linux target, I had an error : "LabVIEW : An input parameter is invalid. For example if the input is a path, the path might contain a character not allowed by the OS such as ? or @. The file 'xx' is not a valid LabVIEW file."
The folders exist and I don't know what I can change ?
You must check the characters you put in the path. On Windows, you can use whatever you want (spaces, accent,...) but on Linux, you must be careful because not all characters are allowed. Change all your accent and remove all special characters.
