Difference Between 9213 and 9214 Thermocouple Modules
Updated May 20, 2025
  • NI-9213
  • NI-9214
What are the main differences between the two C-Series Thermocouple modules: NI-9213 and NI-9214?
The 9214 has a terminal block added onto the module which increases measurement accuracy and provides additional cold junction compensation.
The accuracy section of the specifications document for these models shows the best illustration of these differences. Refer to the NI-9213 and NI-9214 documents.
The 9213 also has an available model that is conformal coated to protect against moisture. This is not available for the 9214.
For more information about these and other temperature modules see C Series Temperature Input Module.
