Copying Just Substeps from a Custom Step Type in TestStand
Updated May 9, 2018
  • TestStand
I am creating a custom step types in TestStand,and I want them all to have the same base substeps. How can I do this?
TestStand allows you to combine two step types into one. A way to get the behavior you like is to create a custom step type with just the base substeps you want. Then you can create your custom step type and combine it with the base step type. This will create a new copy all the substeps from your base step type, and all the other settings from your desired step type.
