No, M-Series does not support multidevice tasks.
For information on synchronizing M-Series devices, refer to M Series Synchronization with LabVIEW and NI-DAQmx .
For a list of device families which do support multi-device tasks, refer to the DAQmx Help Documentation regarding Multidevice Tasks .
If you want to test whether two particular devices support multidevice tasks, try simulating the devices in NI-MAX and creating a new AI task which utilizes one channel from each. If this process results in an error (ex. Error 201426), then multidevice tasks are not supported.
