NI software currently does not come with any native support for creating built-in Telnet, SSH, RLOGIN, or RAW client functionality in your applications. The LabVIEW Internet Toolkit is obsolete as of August, 2014. Certain APIs, specifically the Telnet API,
have been deprecated.
The following third-party software allows networked communication: (
Disclaimer: Third-Party Add-Ons for LabVIEW are offered by independent third-party providers who are solely responsible for such products. NI shall have no responsibility whatsoever for the performance of the Third-Party Add-Ons).
- The labSSH Toolkit from Labwerx adds Native SSH, SCP, and SFTP support to LabVIEW. labSSH allows you to interact with a remote computer using a secure shell, transfer files, and manage remote file systems with a built in VI library.
 - The LabSSH library from Labvolution adds SSH support for communication with remote machines in LabVIEW.
 - The LIBSSH2 for LabVIEW adds SSH client support to LabVIEW using the libssh2 library. However, this only adds client-side SSH support, and does not add SSH server support.
- The PuTTY software package also has a command-line interface to the PuTTY back ends named Plink that can be easily used by LabVIEW, LabWindows/CVI, or TestStand. To do so in LabVIEW, dynamically build a data script file that you can pass to Plink (PuTTY) via its command line options. Then, communicate with and launch the plink.exe executable:
- In LabVIEW, use the System Exec VI, which is accessible from the Functions Palette by selecting Connectivity » Libraries&Executables
 - In CVI, use the LaunchExecutable() function
 - In TestStand, use the Call Executable step type
