How Do I Find or Modify My Device's Name?
Updated Jul 8, 2020
  • System Configuration
I have several NI devices and I want to modify their names or "alias" in order to find them easily next time I connect them.
How can I find and modify my device's names?
In order to find and modify the names of the devices connected to a specific computer, you can:
  • To do so manually:
    1. Open Measurement & Automation Explorer (NI-MAX).
    2. Expand My System >> Devices and Interfaces where the devices are listed.
    3. Right click the device you want to rename and select Rename.
  • You can also do this programmatically. Refer to the Related link section for examples of doing this.
NI-MAX will remember the module name on a specific slot of a specific chassis. If you move the module to a different location in the same chassis or a different chassis, you will need to rename it. The same happens if you insert a module on a previously named slot.
For more information about using NI-DAQmx driver on NI-MAX, refer to the Getting Started with NI-DAQmx: Measurement & Automation Explorer (MAX) Functionality
