Why CAN Interfaces Are Not Updated in My cRIO Project When I Add a 9862 Module?
Updated May 28, 2018
  • NI-9862
  • NI-XNET
I already have a cRIO with a 9862 module and the CAN interface is present both in my project and in MAX. However, when I add a second 9862, I can add the module to the project but the CAN interface is not autopopulated in the code nor present in MAX. How can I make it accesible?
In this case, even if the FPGA code is not modified, the FPGA VI needs to be recompiled in order to add NI XNET support to the added modules.
