Can LabVIEW be Used to Configure Settings in FlexLogger?
Updated May 1, 2019
  • FlexLogger 2018 R2
I am looking to use LabVIEW to interact with FlexLogger and configure a trigger. Is this possible?
FlexLogger 2018 R2 does not currently have an API that is accessible in LabVIEW, so this is not inherently supported.
You could configure a trigger in FlexLogger 2018 R2 based on a Channel Value Change and then use LabVIEW to force a change on that channel.
Note: FlexLogger 2018 R4 introduced a new feature that allows data exchance between LabVIEW using Skyline tags. For more information see Using NI Skyline Tags to Exchange Data between FlexLogger and LabVIEW.
