Can I Connect a CAN Device That Not Require a Powered Bus to a Powered Bus?
Updated May 7, 2018
  • CAN Interface Device
I have a CAN device that does not need a powered CAN bus. Can I use it with a powered CAN bus?
If your device does not require a powered CAN bus you can use it with a powered CAN bus as well.
