Using Keyboard and Mouse in National Instrument's Real-Time Controllers
Updated Sep 21, 2018
  • Industrial Controller
  • CompactRIO Controller
  • CompactDAQ Controller
  • LabVIEW Real-Time Module
Can I use a keyboard and mouse in my NI Real-Time Industrial Controller (IC, CompactRIO, CompactDAQ)?
Refer to the document Which Real-Time Targets Support Embedded UI? to understand whether your real-time target supports Embedded UI functionality. Typically all Industrial Controllers(IC) support Embedded UI functionality.
To enable this feature in your application, refer to the help document: Enabling the Embedded UI on RT Targets (Real-Time Module)
Typical Real-Time targets do not support mouse and keyboard usage in the application, however the Embedded UI enables you to access a desktop environment on your RT target from which you can browse files, access terminals and settings, and interact with the front panel of a VI running on the RT target using a mouse and a keyboard.
National Instruments uses Xfce to create the embedded UI for RT targets. To learn about using and configuring Xfce, refer to the Xfce help available on the Xfce website.
