ZIP Damaged Error When Unzipping Software Downloaded from NI Website
Updated May 3, 2018
When I try and unzip a download file I got from the NI Downloads Page, I get an error that says the following:
ZIP Damaged: <file path>: Bad CRC. Possible cause: file transfer error
What should I do to fix this?
If you encounter this error, try downloading and unzipping it on another machine, to rule out the possibility of a corrupt file or transfer problem. Then you can transfer the unzipped folder via USB flash drive or other media, and install it on the computer in question.
