If timing violations occur even when compiling a minimal FPGA design, the issue may be related to the local FPGA compilation environment rather than the FPGA application itself.
To help isolate compilation-environment issues:
- Navigate to
C:\NIFPGA\compilation and remove any existing compilation folders. - Compile the FPGA project that is generating the timing violation.
- Review the newly generated compilation logs in the folder created under
C:\NIFPGA\compilation. - Remove the generated compilation folder.
- Create and compile a blank FPGA VI for the same target.
- Compare the compilation logs from the blank FPGA VI to those generated by the original project.
These steps can help determine whether the issue is related to the FPGA design, the Xilinx compilation tools, or restrictions affecting the local compilation environment.
If local compilation issues are suspected, also verify the following:
- Run LabVIEW with administrative privileges and compile from a short local project path such as
C:\FPGA_Test. - Confirm that the
%TEMP% and %TMP% environment variables resolve to local folders and not redirected, synchronized, or network locations. - Review Windows Security Protection History and any endpoint security software logs after a failed compilation.
- Verify that antivirus or security policies are not blocking:
vivado.exexvlog.exexvhdl.exe- NI FPGA compilation worker processes
- Write access to
C:\NIFPGA
If security exclusions must be configured, consider reviewing:
C:\NIFPGA%TEMP%%TMP%- Vivado executable files
