Can I Internally Route Counters on the PCI-6602?
Updated May 10, 2018
  • PCI-6602
  • Counter/Timer Device
I am trying to test the counters on my PCI-6602 by outputting a pulse train and counting the edges but I am not seeing these edges when I try to route the counters internally. Is there a way to accomplish this?
There is not a way to route counters internally on the PCI-6602 so you will need to connect the counters to different PFI lines, then connect those PFI lines with wires. Once the output is connected to the input you will be able to work with these counters.
