Hang Error On Remote Front Panel
Updated May 25, 2018
  • LabVIEW Real-Time Module
  • NI Linux Real-Time
  • PharLap
I am trying to use a remote front panel to interact with an executable hosted on my real time controller. However, when I direct my browser to the html file on my real time controller the remote front panel just hangs with the following message:
Downloading Panel 0.00% of 0 bytes
There are two solutions to this problem depending on the underlying cause:
  1. Your firewall or anti-virus is blocking communication between your host system and the real time controller. In this case ensure your systems can properly communicate with each other by setting the appropriate exceptions to your firewall and anti-virus.
  2. You are missing the necessary software to properly set up the remote front panel. Ensure you have installed all the necessary software as detailed in: National Instruments Product Compatibility for Microsoft Windows 10
