How Can I Get BNC Connections on the PXI-6738?
Updated May 10, 2018
  • PCIe-6738
  • PXIe-6738
I have a PXIe-6738 and would like to interface with it using BNC connections. What options do I have?
Per the Cable and Accessory Compatibility Table for the PXIe06738, there is not a BNC terminal block option. However, you can create a custom connectivity solution using the CA-1000
