Does the C Series Modules Have to Be Inserted In the cRIO When Installing the Software On It?
Updated May 18, 2018
  • CompactRIO Controller
  • LabVIEW Real-Time Module
I do not know if the C Series Modules have to be inserted in the cRIO when Installing the software on it.
What if I unplugged any of them and the Software is already installed in the cRIO.
The software will be installed in the cRIO regardless the modules are connected or not.
C Series modules are hot swappable, if the system is in a nonhazardous location, the chassis power can be on when you install modules.
