How to Hide the Startup VI From Taskbar?
Updated May 25, 2018
I want to hide exe file from taskbar. I have designed the startup Exe for my VI. When the exe file is launched unfortunately, it is not getting hide in taskbar.
Use the following VI as a testing template:
Once you create the exe file you will have a ini exe file, edit it adding the following statement:
HideRootWindow=True
