Disable VBAI Local Engine Window When Running Vision Inspection in LabVIEW
Updated Mar 23, 2020
  • Vision Builder for Automated Inspection
I am developing my vision application in LabVIEW using NI Vision Builder for Automated Inspection (VBAI) API. Whenever I run the VI calling the VBAI's functions, the VBAI engine window will prompt out on screen showing the VBAI inspection details. How do I disable the window?
To disable the VBAI Engine window from prompting out to your screen when running inspection in LabVIEW, you can wire a False constant to Show VBAI Engine (True) terminal of VBAI Interface - Launch Local VBAI Engine .vi as illustrated below:
By default, Showing VBAI Engine is set to True. Showing the details is useful to debug the inspection status and iteration count. Setting false will enable the engine to run silently as a background application.
