To convert a 2D array to a waveform data type, you need to use
Build Waveform function. Input the 2D Double Array data type into the function as the data value of the waveform and the output will be in waveform data type. The function can be found in the
Functions pallet >
Programming >
Waveform >
Build Waveform
The waveform default Start Time (t0) value is
00:00:00.000 PM DD/MM/YYYY and the default Time Interval (dt) is
1 second. Input an existing waveform or change the constant values if you want to set different waveform components value.
