Enable Voltage Autoranging for DMM PXIe-4082 in Frequency Measurements
Updated Jul 26, 2018
  • PXIe-4082
  • NI-DMM
I'm trying to acquire frequency measurements using PXIe-4082, and the voltage magnitude for the measurements vary. How can I enable auto-ranging?
The NI Digital Multimeters Help document for Configuring Auto Range outlines that the  PXIe-4080/4081/4082 does not support Auto Range for Frequency Voltage measurements. So in order to change the range you will need to use niDMM Configure Frequency Voltage Range VI.
