Error 35025 When Attempting to Send CAN Frames
Updated May 4, 2018
  • sbRIO-9627
  • NI-CAN
  • NI-XNET
I am trying to send CAN frames using my sbRIO-9627, but I am getting error 32025 (Bus Off). What should I do to fix this?
Recovering from the Bus Off state can be done by calling the following VIs in this sequence/order: (make sure to properly clear and handle errors). You should not have to reboot or power cycle after completing these steps.
  1. CANCloseInterface vi
  2. CANCreateInterface vi
  3. CANStart vi
If this does not resolve the behavior, you should format your sbRIO and reinstall software to it.
