How Can I Find Differences Between Two Sequence Files in TestStand?
Updated May 11, 2018
  • TestStand
I have two TestStand sequence files and I would like to find out what differences they have, such as differences in steps, differences in variables, etc. Is there a tool I can use to do this?
TestStand versions 2010 and onwards installs with the TestStand File Diff and Merge Utility, which you can use to compare two sequence files or station global ini files to check for differences between the two or to merge sequence files.
