How Can I Quickly Test If My DAQ Device is Working Properly?
Updated Dec 28, 2023
  • NI-9233
I have a DAQ card or module, and I would like to test it to make sure that it is fully functional and within its specification limits. How can I do this quickly?
NI MAX has a functionality that is included with the NI-DAQmx driver  called Test Panels , which allows the user to initiate basic signal input or output with minimal set up. Use this with an oscilloscope or DMM for output testing or a function generator with a known signal output for input testing.
Make sure that your DAQmx driver is compatible with your operating system and LabVIEW version
