Generic File I/O Error When Doing TDMS Logging on cFP-2220
Updated May 4, 2018
  • cFP-2220
  • NI-FieldPoint
I have a program that logs TDMS data to a cFP-2220 system. Whenever I try to run the TDMS logging program it errors out with Error 6: Generic file I/O error. The error occurs when the TDMS file is first created. Running the same program, changing only the path, on a Windows desktop system works without error.
Why doesn't writing TDMS files work anymore?
If you run into this behavior, there are a few troubleshooting steps you can try:
  • Recompile the code on your cFP
  • Reformat and reinstall software on your cFP, then try deploying and running your code
