No. When an executable is built, the Run-Time Engine dependency is defined by the development environment used to create the executable.
Therefore, make sure that you match the version of LabVIEW Run-Time Engine to a compatible version of the Development System.
There are two options that will allow you to successfully run a LabVIEW application:
- The target PC will need the correct version of the Run-Time Engine. Versions of the LabVIEW Run-Time Engine are freely available for download online through the LabVIEW Download page
- The application will need to be built in the correct version of the development environment. Learn how to download previous versions of NI software.
Note: Beginning in LabVIEW 2017, you are able to configure your executables to run with future versions of the LabVIEW Run-time Engine.
