Reduce Size of TestStand Sequence File
Updated May 15, 2018
  • TestStand
My TestStand sequence file is very large, how can I reduce the size of the file?
Sequence Files can be saved in Binary, XML and INI file format.
Binary format is the smallest among the three and saving the sequence files in binary format will reduce the size of the sequence file.
To change the file format of the sequence file, access sequence file properties in Sequence Editor using Edit >> Sequence File Properties menu.
The Sequence File Converter tool can also be used to modify the format of sequence file.
