The RMX-4101 requires the
NI RMX-410x Power Supplies driver. The RMX-410x is a plug and play instrument driver, so the installation process is different as compared to other NI drivers, such as NI-DCPOWER. Follow the steps below to complete the installation:
- Identify which version of the driver best fits your application based on supported devices, OS and application software.
- Download and extract the .zip file hosted on the download page.
- Open the folder for the extracted file and move the contents to one of the following directories dependent on your LabVIEW version:
- For 32-bit LabVIEW: <National Instruments>\LabVIEW XXXX\instr.lib
- For 64-bit LabVIEW: <National Instruments>\LabVIEW XXXX\instr.lib
"XXXX" refers to your LabVIEW version.
Upon completing these steps, the API for communicating with the RMX-4101, RMX-4102 or RMX-4104 will be available in the Instrument I/O section of your LabVIEW Functions Palette.
