Getting TestStand Error: Cannot Index an Empty Array
Updated Aug 24, 2018
  • TestStand
I have a TestStand sequence file that makes call to sequences in another sequence file. When I run the program, one of the LabVIEW VI calls in the other sequence file returns an error, saying "Cannot index an empty array." Why am I getting this error?
This error often occurs when a step's parameters include File Global variables that are populated in the original sequence file. Because File Global variables are only local to a specific file, the other sequence file does not have access to them.
There are two solutions: either pass the data to the other file as a parameter, or make the variable a Station Global variable instead.
