Can't See PXIe-78xxR in NI MAX
Updated Mar 27, 2019
  • PXI-7813
  • PXIe-7858
I have a PXI R-Series module (78xxR) in a PXI chassis. I can see the PXI controller and chassis in NI-MAX, but I can't see the module.
  1. Make sure that you have the following device drivers installed:
    1. NI FPGA Module
    2. NI R Series Multifunction RIO
    3. NI-RIO Driver
  2. Make sure that the correct version of the NI-RIO driver is installed by checking the NI-RIO and LabVIEW Version Compatibility. The version of the FPGA driver should match the version of LabVIEW that you are using.
  3. If you already have these drivers installed, repair the NI-RIO Driver and/or NI R Series Multifunction RIO.
