This could be happening because the library is being copied to the wrong directory. Normally there are two National Instruments directories in the hard drive (C:), one in
Program Files and one in
Program Files (x86). In the first one you will find files corresponding to 64-bit software and in the second one you will find files related to 32-bit software.
- If you are using LabVIEW 32-bit, make sure to copy the library to the folders in the National Instruments directory located in the Program Files (x86) directory.
- If you are using LabVIEW 64-bit you must copy the library to the folders in the National Instruments directory located in the Program Files directory.
