Error 1143 With LabVIEW DataSocket Application
Updated Sep 30, 2025
  • OPC Servers
  • I'm receiving Error 1143 when I attempt to run my LabVIEW executable that uses DataSocket. How do I properly distribute a LabVIEW application built with DataSocket?
  • My LabVIEW Executable gives Error 1143 when I try to run it. The OPC Server Quick Client works, but I receive this error when trying to read with the DataSocket API.
To run a LabVIEW application that uses DataSocket, you must install NI DataSocket on the target computer.
When you create an installer in LabVIEW, you can include support for DataSocket by checking NI DataSocket under the Additional Installers category.
Note: In LabVIEW 2015 and later you may need to first uncheck Only display runtime installers under Additional Installers.
As an alternative, you can distribute the stand-alone NI DataSocket installer from the below directory in your LabVIEW development environment.
C:\ProgramData\National Instruments\MDF\ProductCache\
