Does LabVIEW require OBDC?
Updated May 22, 2018
  • LabVIEW Database Connectivity Toolkit
 Does LabVIEW eliminate the need for using ODBC and use a native SQL driver instead or does it still require ODBC?
All data access in the LabVIEW Database Connectivity Toolkit occurs through an OLE DB provider. If you do not specify a provider, the toolkit uses the OLE DB Provider for ODBC provider. Microsoft provides some relational data providers as part of the MDAC installation.
For more detailed information see LabVIEW Database Connectivity Toolkit User Manual: Chapter 2 OLE DB Providers.
