Error: This VI is not executable. The full development version of LabVIEW is required to fix the errors.
Updated May 18, 2018
I used an installer build that was supposed to generate all necessary installers for operation.
When I start the program, it asks me to manually locate a .NET assembly, even though the assembly is present in the data folder. I have installed .NET framework 4.0 and 3.5.
When I installed LabVIEW and DAQmx  on this PC to try to see if they would run in the development environment, everywhere I have some DAQ functionality installed, it says that the VI failed to compile.
You may be missing a 3rd Party device driver. Please ensure all the needed non-National Instruments device drivers are installed.
