Minimum Switch Load for Reed Relays
Updated May 14, 2025
  • Reed Switch
I know that some NI switches specify a minimum switch load or wetting current to successfully operate the relays. Do NI switches featuring reed relays have these minimum requirements?
Reed relays do not have minimum switching requirements or wetting currents. Other switches may specify these minimum requirements because low voltage or current switching signals do not have the ability to vaporize pollutants that can accumulate on the mechanical components of the relay, preventing them from operating. This is not an issue with reed relays because they are contained in a glass container that is filled with an inert gas.  This removes the need for any wetting current, as no pollutants can build up on the relay to prevent mechanical action from occurring.
