Is it Possible to Edit the Value of Variable Using Deployment License in TestStand
Updated Sep 10, 2018
  • TestStand
I have a TestStand deployment license, can I edit the variables in TestStand sequence with this license?
The Following is the difference between the TestStand Development and Deployment licenses :
1. Development : Gives you full access to change your sequence, code modules etc.
2. Deployment : You can only execute the test sequence and cannot make any changes to the test sequence. If your user interface(created using the development license) allows you to change the value of a variable in run-time, then this should be possible. However if the developer has not given you this access, it will not be possible.
For more detailed information about the licensing available in TestStand, refer to TestStand Licensing for Deployment.
