Enable LIN Checksum Corruption With NI-XNET Driver
Updated Apr 24, 2018
  • NI-XNET
I am using a LIN device with NI-XNET driver.
On NI-XNET 14.0 readme page, I found the following note:
Added support for LIN checksum corruption
How can I enable and use this feature in order to test ECU behavior when a corrupted checksum is transmitted?
You should use LIN Frame property Transmit N Corrupted Checksums to cause the next N number of checksums to be corrupted.
If you are programming in LabVIEW, you should perform these steps:
  1. place a XNET Session Property Node in your block diagram. You can find it in Function Palette » Measurement I/O » XNET
  2. right-click the node and select Select Property » Frame » LIN » Transmit N Corrupted Checksums as shown below:
